    Default subfloor from kitchen extends into living room
    after tearing out carpet to redo hardwood floor noticed subfloor from kitchen extends about an inch into living room where i want to redo the hardwood floor. any ideas on what i should do about this?
    7,243
    Default Re: subfloor from kitchen extends into living room
    Yup! That's what I'd do. Another solution would be to have a flooring spe******t replace that strip of underlayment with a strip of hardwood, though I would say that this is only an option if you'll be having other floor repairs done as well, due to expense. The fastest and easiest thing will be to use a transition strip as mentioned.
    Quote Originally Posted by asc2078 View Post
    That is so narrow, that you might consider simply adding an oak transition strip to match the floor.
    thanks for the idea. that really will help
    cool thank you
    7,243
    You're welcome, let us know how it goes.
