    Default Tiling over tongue and grove pine walls
    I'm preparing to tile over a wall that is 5/8" thick tongue and grove pine. I have a two part question. #1 - can tile be installed over tongue and grove material? There is about a 3/8" wide by 1/8" deep indentation where each of the boards meet that runs the entire joint. #2 - If I can, can I tile directly over the wood wall with tile mastic or do I need a vapor barrier and sheathing for proper adhesion. BTW, this wall is in a bathroom but will not be exposed to moisture. Thanks
    Hudson Valley New York
    25
    Default Re: Tiling over tongue and grove pine walls
    Tiling over tongue & grove material is not recommended because during the winter and summer months, the tongue & grove material will expand and contract with the humidity and the tiles will become loose. However, if you do not want to remove the tongue & grove material and want to tile over it, I suggest you install 1/4" hardy backer board over the tongue & grove material and then tile over the board.
    Cyril Prendergast
    Kitchen, Bath and Home Remodeler
    Serving the Hudson Valley, New York
    www.yourconstructiongroup.com
