Thread: 2 part epoxy
    Default 2 part epoxy
    I recently saw Tom in an Ask This Old House segment use a 2 part epoxy to repair rot in windowsills prior to painting. The epoxy was in large tubes like caulking, and dispensed from what looked like a two barrel caulking gun. Can't seem to find this product in my area. Does anyone know the name of it so I can locate it?
    thanks,
    Russ
    1,950
    Default Re: 2 part epoxy
    Russ -
    Home Depot sells a 2-part epoxy product which is intended for setting concrete anchors in concrete. It is a twin barreled caulk gun apparatus. Just an idea.
    For years I have used "Bondo" for filling rotted wood, woodpecker holes and open knot holes. It is a polyester product with a catalyst which sets in about 5 minutes. Min-Wax sells something very similar as a wood filler, but it is more expensive. Bondo sells for about $10 per quart. MinWax has a wood conditioner which acts as a bonding agent before the wood filler's use. You want to clean out all the rotted wood first. I then splash straight Clorox on the area and then let it dry. Both products can be rasped and sanded smooth after dry. Bondo doe not schrink and being a plastic, does not absorb water so it is stable in exterior apllications.
    Sep 2009
    Tom used a product made by Advanced Repair Technologies. You can find the product here...
    http://www.advancedrepair.com/
    -Kev
    Aug 2009
    Ladson,SC
    192
    Look into this product Abatron Inc.
