    Default How to clean hard water spots on glass shower doors
    How do I clean hard water spots on glass shower doors?
    7,078
    Default Re: How to clean hard water spots on glass shower doors
    Quote Originally Posted by kjensj View Post
    It's been a long time since I've had to deal with this issue. I have found most hard water stain removers and home remedies don't work, what does work is to use a single sided razor blade for heavy build up, then use water spot remover from the automotive store. While you're at the auto parts store, also pick up a bottle of Rain-X. Once you've gotten the water spots removed, give the glass a good couple coats of Rain-X, which will reduce the spotting and make cleaning much much MUCH easier.
