Results 1 to 7 of 7
    Sheboygan Wisconsin
    Post Door knob replacements
    Help! I'm remodeling my sister's house and we'd like to replace all the old discolored worn interior doorknobs - bed/bath and closet. Problem I'm having is I'm looking for tulip or bell shape which I can find, but the doors have a 3/4 to 7/8 inch latch bore and all I can find are ones that require a 1 inch latch bore. Can anyone direct me to a source? Am I going to have to re-drill all the doors? The old ones are Harloc but I can't find them anywhere.
    Thanks for your help.
    5,942
    Default Re: Door kob replacements
    Try Yale Harloc. My guess is if you are going from 3/4 to 1" you will have to drill out the doors.
    Sheboygan Wisconsin
    Default Re: Door knob replacements
    That's what the originals are and I haven't been able to find Harloc anywhere - even ******. Know of any vendors that carry them?
    Thanks.
    5,942
    Sheboygan Wisconsin
    Thanks, guys. I reviewed the sites and nobody has the style that she wants - good old tulip or bell, in polished brass. They're not old enough to be antique or restotation - just old. I will attempt to drill out the latch bore on the least-obvious door (in case I get it crooked) and just buy what's available on the shelf with a 1 inch latch bore.
    I really appreciate all your help on this. It's nice to know there are wise people out there willing to share!
    Nan
    5,942
    I would suggest you pick up some 3/4" dowel, tap it into the hole to provide a solid center for your drilling.
    Chicago, IL
    162
    You can make a template similar to this one
    from 3 pieces of 1 x 4 material. Drill a 1" hole in the proper position in the piece that fits over the edge of the door, and clamp your homemade jig to the door. Then use a hole saw, rather than a spade bit to rebore the edge of the door. The jig will guide your hole saw.
    HTH
    Dave
