Thread: copper gutters
    Default copper gutters
    I have copper gutters & downspouts. One downspout has a 2 - 3" split at the seam. One downspout is leaking where the previous homeowner attached an extension with screws. Anyone have any knowledge as to how to repair?
    Sep 2007
    Long Island, NY
    269
    Default Re: copper gutters
    You could solder a copper patch on or I'd probably sand it clean on the inside. Buy a "tube" of Karnak flashing cement and smear some over the crack. I'd also use some membrane first but I think you'd probably have to buy a whole roll. Home Depot may have small rolls for under ten bucks.
    Just cut a patch of it and imbed it into the Karney....smooth it out and add a bit more Karney over the membrane and you should be good to go.
    edit: If the patch is in a real conspicuous area and you don't like hgow the Karnak patch looks (if it's visiable) you could cut a piece of the copper downspout at the bottom of the spout if there's enough extra and push it into the wet karnak to disguise the patch.
    Hidden Content
    ॐשָׁלו
