    Suburb Chicago
    28
    Default Basement floor drain
    I am putting a apd and indoor/outdoor carpet on my basement floor. There is one drain tile, which I do not know where it leads to. I put water down it and it flowed somewhere. Should I do something with this drain before laying the carpet? Thanks
    Georgia
    150
    Default Re: Basement floor drain
    There are caps available for floor drains. You need to go to a plumbing supply place. Measure the size of the drain and measure the distance between teh screws. Then you can find a cap that will fit.
    5,940
    I would install a ball valve. it lets water out but closes to prvent water from comming in.
    Unregistered Guest
    Thanks tb and JL
