    Default old cabinets doors
    hi
    i just put new hinges on kitchen old cabinets doors but don't line up one door has a lip that goes under the other one the house is from 1949
    7,906
    Default Re: old cabinets doors
    Assuming these hinges are standard surface mounted hinges, if they are binding where the doors meet in the center, you can spring the hinges a little by closing the doors with a small wedge between them, forcing them apart. If it is a horizontal alignment problem then resetting the screws will be in order.
