    Default Sealing a Granite Countertop
    What should I look for in a penetrating granite sealer? I do not know what variety of granite it is.
    980
    Default Re: Sealing a Granite Countertop
    go to granquartz. com and you will find some good sealers or go to granitecitytool.com both of these are the very same companies that I buy from. if this is for your personal buy the smallest they have it doesn't take much. make sure the surface is clean before sealing it. clean with denatured alcohol first and let completely dry then seal.
    980
    gran quartz 413S is what I use.
