Results 1 to 10 of 19
    Default No Ground On My House
    MY GROUND FOR MY HOUSE I BELIEVE IS ON THE WATER MAIN, SO IF MY HOUSE WERE TO GET STRUCK BY LIGHTENING AND I WAS ON THE PHONE I WOULD BE DEAD. SO MY QUESTION IS HOW DO I PUT A GROUND ON MY OLD HOUSE?
    Denver, CO
    666
    Default Re: No Ground On My House
    Call an electrical contractor.
    Shamokin, Pa.
    645
    Quote Originally Posted by keepdreaming_21 View Post
    You might be dead on the phone or you might be dead on the John....
    Apr 2008
    Houston, TX
    62
    You will need to have a grounding rod installed. There are so many stipulations on where, how deep, how many you need, etc, that calling in an electrician to evaluate what you have is likely the best thing to do. It is fairly common for the electrical system to be grounded to the cold water pipe, but this is usually only secondary to the ground rod.
    Shamokin, Pa.
    645
    Quote Originally Posted by JEWEATHER View Post
    I agree that there are stipulations. But your local code officer should be able to provide them. And if you feel you can work inside a panel box, it is something a homeowner could tackle....
    6,055
    Just as a point of interest, having your home grounded or not doesn't effect the phone. The phone system is independent or the electrical system with the possible exception of a power supply for a wireless phone or fax. If you get your house properly grounded you could still get killed using a phone during an electrical storm.
    It seems that's an advantage of the cordless phone.
    Curious .... what's the stats. on people being electrocuted using the land line phones?
    Shamokin, Pa.
    645
    Round here the local cable company grounds their demarcation boxes with a strap to the meter base. I always thought that was odd.
    6,055
    I don't know, but I have seen a lot of computers blown up that had dial-up modems. It's probably about as many as get electricuted taking a shower during a storm.
    The deep South
    459
    I have seen some surge protection units in the phone Demarc boxes . That's probably what the ground is for .
