Thread: Pot Rack
    Default Pot Rack
    I would like to make a cheap homemade pot rack. It needs to be a long one (2 ft) that hangs on a wall rather than from the ceiling. I will attach it to a wall with panelling, and I may not be able to attach it to studs.
    Does anyone know what the best materials/parts to use are for both functionality and physical appearance? Also, can I use wall anchors in panelling?
    Historic Newton, NJ
    5
    Default Re: Pot Rack
    I suggest you check out the following website www.potracks.com they have an unbelievable selection of wall mounted pot racks and great prices. More important than that is to treat yourself to a cheap stud finder. You really need studs to support the weight of pots and pans.
    Good Luck,
    Di*
