Thread: Noisy Toliet
    Phoenix, AZ
    Default Noisy Toliet
    I have a toliet that make much noise when the tank is filling up with water. The other toliets in my house are very quiet. What can I do the make this toliet more quiet?
    Default Re: Noisy Toliet
    You could reduce the flow by throttling down the supply valve, but this will also slow down the tank's refill time.
    It may be time for a new toilet fill valve, which are quite easy to install. A new fluidmaster fill valve is around 15 bucks at most hardware stores.
    How to replace a toilet fill valve
    Plumbing and Heating Tech.
    My plumbing website Hidden Content
    Dec 2009
    Chippewa Lake, Ohio
    Cool Re: Noisy Toliet
    You didnt say what type noise was coming from the toilet. Sometimes a loose hanger on a pipe will allow vibration or knocking as water passes through. Other times an accumulator is needed to offset noise due to imbalance in the system and of course there is always the possibility the water valve may just be worn from usage.
