    Jul 2008
    Orlando
    Red face New PVC piping attached to old broken copper pipebath fixtures...help!
    My 50 year old house had to be re-piped. I have loved the PVC **** which runs through the attic and has made renovation so easy! But now the old fixtures in a shower bath can not be fixed again. There is a panel behind the fixture wall so I have easy access to it. Now I need guidance to cut off the original copper where the PVC was glued and add new fixtures. Does anyone know of a visual guide for extending PVC and what type of fixtures connect to it best for the shower/bath wall. The only complication is that the handle for switching from faucet to shower is copper pipe up to the shower. I'm retiling so those don't matter either. I just need good directions and advice! floridafriend@earthlink.net
    Jul 2008
    San Francisco , Ca
    43
    Default Re: New PVC piping attached to old broken copper pipebath fixtures...help!
    why on earth would you wanna replace copper tube with plastic crap..? are you saying that plastic is glued straight to copper tube..?
    Nashville, TN
    149
    on the shower valve itself you will need to make the transition to a THREADED fitting. The reason is this is how you are going to go from the valve to the CPVC. The CPVC has a MIP and a FIP adaptor with brass male/female threaded parts in the fitting itself. MAKE SURE TO USE PIPE DOPE. I recommend Recto SEal #5, and it is a yellow paste that will firm up, unkike straight teflon dope.
    Now here is the kick. The shower valve may have only sweat connection. And if you sweat the joint without taking out the valve cartiidge you will warp it. Also, if you don't know how to sweat copper it may be a problem. I have seen ALOT of plumber mess this part up in both residential(custom baths) and commercial(hotel). You really need someone who has done this part before. I will compare it to the first time trying to fix a flat tire on the side of a very busy road, at night, in the cold, in the rain. But, once you do it you will say "oh, that was easy" and think nothing of it.
    Process of elimination. Good luck.
