Results 1 to 1 of 1
    Apr 2008
    16
    Default Vinyl Eraser and Arbor attachment work to remove silcone along tile and showerdoor?
    good or bad to use?
    intended use:
    Vinyl Eraser And Arbor
    You can remove all vinyl pinstriping, graphics, and adhesive residue without damaging the paint. Simlpy mount the eraser in your air drill (recommended speed is 3,500 to 4,000 rpm.) and safely remove all the old body striping in minutes. Unlike chemicals and solvents commonly used for this job, the soft wheel is gentle to the finish. Not recommended for acrylic lacquer or plexiglass.
