    Default Slatwall Hangers
    Does any know where you can get the brackets(hangers) that fit into slatwall but without any hooks on them so they can be attached to your own tool hangers. I have seen these on some displays in the plumbing dept at Lowes but can't find any place that sells them.
    Default Re: Slatwall Hangers
    You'll probably have to check with a department store fixture supplier.
    Google "slatwall hardware" and see what you come up with. You may need to contact the suppliers directly.
    This was the first hit I got from Google
    Also, check with Charles McMurray and VanDykes, both of those are hardware dealers. McMurray supplies hardware to cabinet shops and such, they'd likely have or be able to get what you need.
    Dec 2009
    Casper, Wyoming
    How about contacting customer service at Lowe's. You can ask them ****** and I am sure they will tell you where they get them. if you like the ones you saw there, then ask.
    We provide the latest information on how to fix, renovate, and decorate your house using the least amount of resources for the best value.
