    ETHEL Guest
    Default Old Painted Wood Floors
    Took Carpet Out Of A House We Just Purchased.house Was Built In 1882. We Want To Go Back To The Original Wood Floors Which Are 5 " Planks Painted A Dark Reddish Brown.should We Repaint Or Sand Seal And Wax.the Wood Appears To Be Asoft Honey Color Under The Paint.house Is In Sw Michigan.
    Thanks,
    Ethel
    6,115
    Default Re: Old Painted Wood Floors
    My personal preference would be to sand , stain if desired, and finish with a floor grade polyurethane. vacuum and damp mop only, I never use wax on floors. If the finish starts to wear, lightly buff with sandpaper or steel wool and add a new coat of poly. IMHO.
