Results 1 to 10 of 12
Thread: nutsedge
    Jul 2008
    Unhappy nutsedge
    just signed up 1rst post question is anyone know any tricks to control or kill nutsedge i know about SEDGEHAMMER gets little expensive for follow up applacations... thanks for any help... I live in S.E.PA.
    Sand Springs, OK
    467
    Default Re: nutsedge
    My husband recommends just digging out the yard and replacing it to be sure that you get the roots.
    If this option isn't appealing then stick with the sedgehammer or call your local cooperative extension office to see if they have encountered a better management possibility.
    Debby in Oklahoma
    New England
    118
    I've been told that its impossible to completely "rid" unless you dig up the entire yard. that even though the "grass" pulls easily out, there is still a "seed" that's left behind, and that's what continues to sprout.
    even folks with professional lawn care services, can end up with this "witch grass".
    find it hard to believe in this day and age, there isn't something
    that can be sprayed on it, to kill it w/o harming the good grass.
    2,009
    Sedgehammer does work and doesn't hurt regular grass because I've used it. It's just a bit expensive.
    It helps to cut the grass a bit low, then wait a few days for the nutsedge to sprout up. Then spray it with a spreader sticker added and then don't cut the grass for at least a week. Because it's expensive I've just spot treated with a pump sprayer and not tried a hose end sprayer over the entire lawn.
    New England
    118
    Smile Re: nutsedge
    I just spent 1/2 the morning looking for Sedgehammer. None of the garden centers around me knew about/sell it. Each tried to sell be Weed-Be-Gone. I did find one person who explained the benefits of using a "spreader sticker". Had never heard of that before, the above post. So I purchases a bottle of that.
    But aside from internet, any idea "where" one can purchase
    Sedgehammer? I'm anxious to try it.
    2,009
    http://www.carrollgardens.com/weed_c...D=420-20-13565
    If this doesn't take you to the page, click on weed control.
    New England
    118
    >Re: nutsedge
    that web site reads the product is, "Not Available This Season".
    so the search continues.
    New England
    118
    >Re: nutsedge
    New England
    118
    >IIRC, at least with was the case with Manage, you need to add a sticker and a surfactant before you spray.**
    While I haven't found the Sedge Hammer yet, I purchased a bottle of Turbo Spreader Sticker. But I find the directions rather vague. How much spreader sticker does one use for a gallon of Sedge Hammer? The bottle says to add sticker to spray to tank AFTER you've added & mixed. It says to mix spreader with 10 parts water. What's a part - an ounce,
    a cup, the bottle? How much spreader sticker is needed per
    gallon of "other" (in this case, it would be Sedge Hammer)
    I also understand that dish detergant can be substituted for a "sticker". Seems a much cheaper way to go.
    2,009
    Quote Originally Posted by crylakel View Post
    >Re: nutsedge
    Give them a call, I think they may have it.
