Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    5,939
    Default Re: Extend length of copper pipe under kitchen sink
    Are you using brass or plastic compression rings? How did you cut the pipe? Did you check the pipe to make sure it had not been deformed? I've seem the crushed in packaging and shipping.
  2. #12
    Jul 2008
    6
    Brass compression rings on the copper pipe and plastic compression rings on the plastic tubing. After I applied too much force to the copper compression ring it started leaking so I cut it off w/ a pipe cutting tool which worked well. The second time I placed a compression ring on the pipe I got it to the point where it tears only once every 10 minutes. Should I just slowly apply more force to the compression nut and hope it does not bust like the old one?
  3. #13
    5,939
    You can try tightening it a little bit more, if that dosen't stop the leak you may need to try a different compression fitting. The problem may be in the body of the fitting rather than the ferrules or the tube. A poorly formed taper is common in mass produced fittings as well a cracks in the threaded heads.
  4. #14
    Jul 2008
    6
    I noticed on my old hot water dispenser faucet that was preinstalled the compression ring on the copper tubing was much slender and the nut could slide outside the ferrule. Also the ferrule was on strong enough to put a slight dent in the copper pipe. The compression rings that Im using have a much wider ferrule with less compression force and the nut does not slide freely behind the ferrule. The first compression ring that broke was not due to an incision in the pipe but a crack in the nut. If there is another type/brand of compression ring you could recommend I would try that.
  5. #15
    Oct 2007
    56
    you need to install brass insert fittings inside of the plastic tubing,youll need 2 of these fittings on for each end,these will prevent the cutting and crimping of the plastic tubing,also it may be easier for you if you cut back the 1/4 tubing from the faucet so that everything isnt jammed so close
