Thread: Old House Locks
    Jul 2008
    Default Old House Locks
    Hi,
    In my 1920s duplex, someone took the old master locks (spring-loaded, see attached pic for sim.) and disabled them on the interior doors, leaving the rectangular box. They then drilled new holes and installed new shiny **** deadbolts. Ugh. Sooo ugly. Here are my questions:
    1) Can I repair the holes in the old doors?
    2) My exterior door has the old master locks right now. No deadbolts. I don't think this is safe. I'd like to install a new lock, perferably a deadbolt, or at least one that latches more securely, but don't know where to look to find a new lock with the old dimensions... it's certainly not something carried at home depot and my local locksmith doesn't know. I can't be the only person in the country with this problem! I don't want to drill a new hole!!! Are there lock makers that specialize in these types of issues?
    Help!!!
    Thanks,
    GG
    13
    Default Re: Old House Locks
    1) I assume the doors are solid wood in which case the answer is "yes". There are a number of ways to patch this using a combination of wood plugs, glue, and filler. If the door is painted this repair should be virtually invisible once complete.
    2) Try Googleing "antique door locks". When I tried that the top results were vendors who offered all manner of replacement hardware for vintage doors.
