Since you have a spring in the basement maybe you could look into using it for the old style evaporative type cooling tower set-up. This is just a thought from a DIYer & dreamer. Low cost, find an old tower tubing & pump. Maybe you could use a windmill or such to move the water. Reduce,Reuse,Recycle. Sometime the old "Tried & true" lasts Good Luck!
