    Jul 2008
    Corona, CA (outside of LA)
    Default How can I reduce blower noise?
    We just moved into our 1990's ranch in southern california and had the A/C condenser/coils replaced (the furnace was in good condition). The unit works great but blower noise is a problem.
    It's not the blower itself, it's the design of the house -- the furnace is situated in a small closet (raised above the air return) right inbetween our family room and master bedroom.
    Is there anything I can do to reduce the amount of noise ... I thought about insulation on the walls of the furnace closet but not sure what kind is best to use in proximity to the furnace.
    Also, would it be ok to install a filter over the air return grate?
    Thanks for ideas/suggestions.
    MN
    455
    Default Re: How can I reduce blower noise?
    I'm not sure of the noise you are hearing but I'm guessing it's velocity noise. That's the air rushing through the return vent.
    Putting insulation on the walls won't do much since the return vent is open anyway.
    I'm thinking if you want a filter over the vent it probably wouldn't hurt but it can't cause to much restriction for air flow.
    Derby City
    42
    I agree, that more information would be helpful in trying to determine where the noise originates. Certainly insulation of the return cabinet would help; although insulation of the closet itself probably would not unless the noise was 'mechanical' in nature.
    Sounds like you have a single return, which is the low-cost way of doing a return system and one of the problems as you are now aware, is that you are pulling the total amount of air in the system back through a single opening. Ideally, you would have a cold air return in each conditioned area of the house, with the exception of the kitchen and / or bathrooms.
    If this cannot be achieved (for example if the house is built on a concrete slab) then you are probably limited to the single return.
    You may want to create an offset of sorts on the return. In other words, raise the return grille to a high-wall location, and then put a duct riser flush with the interior of the closet and have it drop down to connect to the existing return of the furnace. With this offset, you will diffuse the sound and may find it quite acceptable.
    Have a professional come out and look at your system and he can determine the feasibility of what I have proposed. I would not recommend that you attempt any of this yourself, so that in an effort to correct one problem, another is created.
    All the best, Irishmist
    Live your life as an EXCLAMATION; not an explanation!
