Results 11 to 20 of 27
  1. #11
    Default Re: Toilet installation in basement
    Ron ... don't forget to put gravel under the piping for support.
    Just a point for information ... PVC is white and ABS is black.
    Good luck.
  2. #12
    Jul 2008
    11
    Oh I thought it was PVC pipes, it says "medium Grey PVC solvent cement for PVC pipe and fittings" on the glue I used...
    So now is that bad??
  3. #13
    Jul 2008
    San Francisco , Ca
    43
    Quote Originally Posted by RonL View Post
    Most plumbers agreed that this installation should in fact work and that the leak is due to an improper rubber installation. They added that I should remove the rubber and add some silicon material (gasket maker) plus clean the pipe and make it fit more accurately. They mentioned that I should get this done and test it out a couple of times for leaks. The new toilet line should also be slightly in an incline towards the outside just to make the water flow better.
    I did what I was told and so far no leak. I'll testing it some more before finishing the job.
    The pipes are PVC sold in home depot same goes for the glue used.
    sure it will probably work. is it to code no! and these plumbers are ignorant.. for telling you to use silcone gaskets. go to plumbing suppler and get the correct transition bands.. i strongly suggest that you use a wye and 1/8th (45) bend to make the connection instead of the illegaly installed sanitary tee and at least a long sweep 1/4 (90) for the closet bend
    Last edited by Administrator; 07-17-2008 at 01:16 PM. Reason: oooh! you used a naughty word!
  4. #14
    Jul 2008
    11
    For vent, there is a an opening right beside the new installation which is currently closed with a cap (on the pipe going downwards to the ground). I was going to open that cap and install a sink. Will that be considered a vent since the sink has an opening (the sinks drain)?
    I am heading today to the local hardware store to determine another way to this design which I was given by one of the plumbers. It should take care of most of the current issues.
    So now I only have to figure the vent part out.
    P.S. Since here in Montreal temps are pretty cold in winter, what is better PVC or ABS?
  5. #15
    6,005
    A sink is not a vent, it should have a "p" trap that is full of water to prevent venting through the sink. It should have a vent after the trap.
  6. #16
    6,005
    djrenek1,
    I suggest you edit your post, profanity is not considered good form on an open forum.
  7. #17
    Jul 2008
    11
    True I did not think of that, so I'll probably add a Studor Mechanical Vent right before the "p" trap. That can be done later once I work on the sink piping.
  8. #18
    Jul 2008
    San Francisco , Ca
    43
    i have never seen yellow abs solvent period... i'm in sf CA
    as for editing my posts for cussing i can care less.. i'm done with all the igronance as well.. bye
  9. #19
    Jul 2008
    11
    I got the yellow solvent and I also redid the installation. I am now installing the pipes. I also added a backwater valve just in case there are any city floods since this bathroom is in the basement. For some reason here in Montreal the PVC piping are scarce and ABS is the #1 choice. Maybe it has to do with the cold weather we have in winter, I really don't know why for sure.
    djrenek1 thanks for your valued help. I got a Y connection like you mentioned but I changed the placing of the new toilet so now it should be OK (was told to do it this way by several plumbers). I also got better rubber boots made for plastic to metal connections. Since this new toilet is less then 6 feet from the main vent piping, I was told that I do not need another vent installation.
    So the new setup should be much better then the old one. I'll post pictures once I am finished, hopefully I won't get too much negative criticism
  10. #20
    Jul 2008
    11
    here is the new setup:
