Thread: Clothesline
    Unhappy Clothesline
    How do I get rid of a clothesline that is in the ground with quickcrete? Do I dig it out?
    The deep South
    459
    Default Re: Clothesline
    Can you rock it to loosen it up ? Recently , I removed some 4X4 posts by striking the base of the post with a maul , causing the concrete to crack . How much concrete , and how deep ?
    7,599
    If all else fails, digging will be required to remove the post and the concrete core. If you don't care about the core, then the post can be cut off flush with the concrete and left.
