    Smile Adding Another Room
    I want to take down my garage door and close it off for another room.then open a wall next to it..will be doing all this project myself.not a carpenter at all.any advice on materials to use on wall and electrical advice for plugs outlets and lights also.
    I know some of the basics just need some guidedance.this is our first home to buy.need to keep expenses down much as possible.thanks to anyone who can help.Thank You..Goose
    1,387
    Default Re: Adding Another Room
    First find a friend whom has done this and have them help or see if a contractor will reduce the bill if you help.
    Otherwise first learn how to take the tension off the garage door spring cable or risk getting killed.
    Then get a permit from your local building department so when your done your legal & meet minimum standards of construction. Then pick up carpentry, electrical etc books at the library and read and learn. Then make you plans an start.
