Results 1 to 10 of 13
    Jul 2008
    Question Plugs fall out of receptacle
    Our receptacles will not hold plugs tightly. If the cord is moved in the slightest the item that's plugged in loses power and at times the plug will completely fall out of receptacle. Any help or suggestions will be much appreciated!
    Thanks,
    TNLady
    The deep South
    459
    Default Re: Plugs fall out of receptacle
    Replace the receptacles . Cheap and easy fix .
    If all the plugs don't stay in then sounds like it's time to replace the receptacles.
    Oops ... duplicating post ... slow typing.
    The deep South
    459
    Hey , " great minds " ....
    5,774
    And don't buy 98 cent receptacles.
    Jul 2008
    Smile Re: Plugs fall out of receptacle
    Thanks for the answer to my quandry. The contractor must have used really cheap receptacles, the house is only 5 yrs old.
    Thanks Again,
    TNLady
    Pennsylvania
    246
    May I ask you why?
    Also which receptacles should we be using, 10 amp or 20 amp?
    5,774
    Quote Originally Posted by BigWalt View Post
    May I ask you why?
    The cheaper the receptacle the thiner the copper spring contacts. the thinner they are the faster they loose tension.
    Use 15 amp receptacles if you have 14 ga. wire, and 20 amp receptacles if you have 12 ga. wire.
    And always connect wire to screws rather than the plug in stab connections.
    Jul 2008
    Question Re: Plugs fall out of receptacle
    How can I tell which gauge wire I have?
    TNLady
