Thread: split ac
    Amsterdam, NY
    Default split ac
    Can a split AC unit be mounted in an insulated basement, and can the condensation be pumped out of the building?
    Jul 2009
    Northeast
    661
    Default Re: split ac
    Your Air Handler can be installed in your basement, Condenser goes outside, we usually run the Condensate Drain outside but local code may have something to do with that. Good Luck!!!
