Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Jul 2008
    San Francisco , Ca
    43
    Default Re: Strange water heater problem .
    yes hello the reason why this nosie is happening is today water heaters come with pre-installed "heat trap nipples" basically they have these small little balls in them.. (that explains the ball bearing rattling noises) there supposed keep the heat in. i have had sevral customers call and complain about this problem i just remove them and install brass nipples on all my water heaters.
    so remove the short hot and cold nipples from the tank and look to see if you have little balls or some times rubber dampers/ if so install brass nipples if you have copper pipe / or galvinized if you have steel pipe don't forget unions. good luck
    - Sean the plumber
  2. #12
    The deep South
    459
    He has a plumber coming out on Friday . I'll post back with the findings .
  3. #13
    The deep South
    459
    Yep , that was the problem .
  4. #14
    Jul 2008
    San Francisco , Ca
    43
    i knew it...did his plumber know about the heat trap nipples..? or have to trouble shoot for hours
  5. #15
    Kudos to ****hiller for that direction.
  6. #16
    The deep South
    459
    Quote Originally Posted by djrenek1 View Post
    No , sounds like he knew what to try first .
  7. #17
    Jul 2008
    San Francisco , Ca
    43
    ****hiller..??
  8. #18
    Quote Originally Posted by ****hiller View Post
    Fluttering check valve on the inlet pipe, perhaps.
    Scroll 4/5ths of the way down this page.
    http://www.plumbingsupply.com/hotwater.html
    The heater in question may have an older ball type rather than a flapper type. More likely to make the noise you describe.
    Yep..... ****hiller
  9. #19
    Jul 2008
    San Francisco , Ca
    43
    Yep..... ****hiller
    didn't even look at that till now..
