Results 1 to 10 of 19
    The deep South
    459
    Default Strange water heater problem .
    A friend of mine asked me to come over and listen to the strange noises that his water heater was making . It's a KENMORE natural gas unit , about 45 gals. or so . Whenever you turn on any of the hot water faucets in the house , the cold water inlet pipe ( copper ) starts to vibrate and sounds like a bunch of small ball bearings rattling inside . The sound seems to come from the entire length of pipe that is visible before it dissapears down into the wall . The house has good water pressure . Any ideas ? BTW , he just moved into this house and the previous owner said that he heard it as well .
    Default Re: Strange water heater problem .
    size of I/O piping ?
    The deep South
    459
    Uh , yeah . If I remember correctly , seemed to
    be 3/4 or 1 " .
    hmmm ... piping seems to be large enough.
    How about draining the tank to rid of sediment.
    Noise coming from gas models can often be caused by the sediment build up in the bottom of the tank. Steam bubbles form under the sediment. The thumping and popping noises are created by the bubbles escaping from under the sediment.
    Just a thought.
    The deep South
    459
    No , it's coming from the cold water inlet pipe , just as soon as the hot water faucet is opened . It's a rattling sound , like small BB's or ball bearings . VERY strange .
    Yep ... strange.
    The piping seems large enough so you wouldn't think velocity noise.
    If the noise only exists with water flow .. i guess that does rule out the burner heating the sediment.
    .... scratching head.
