    Jun 2008
    St Louis MO
    21
    Default Over the range microwave that doesn't vent outside?
    We're in the middle of a kitchen remodel and I need to find an over the range microwave that doesn't vent to the outside. Reason is, the placement of the microwave and stove will be on a wall with the HVAC ducts right behind them. So, I can't run the vent in the wall and up to the attic and outside. I was going to put a draft hood, but the wife doesn't like them. I can't seem to find any ****** that self vent to the inside. Suggestions or links to some that do?
    Default Re: Over the range microwave that doesn't vent outside?
    There should be a number of units available that have the option to vent inside.
    example .... http://www.geappliances.ca/jsp/ge_Fe...&product_id=13
    You need to purchase the charcoal filter kit.
    Hope this helps.
    Ontario, Canada
    64
    It doesn't work as effectively as the outside one. We used to have one - what a disappointment. Finally we got the real one - outside- what a difference! Try to come up with another plan if possible... Those are my two cents...
    Shamokin, Pa.
    645
    Hope this helps.
    I had always though all units recycle, top vent or wall vent. It just depends on how your needs set up. Also would think a few on the market don't.
