    Missouri
    Default Slick wood stairs
    We have open wood stairs finished with polyurethane that are quite slick. I thought I had read somewhere about something that could added to a top coat to make them slightly rougher without changing the look but I can't find the article. Any suggestions?
    1,387
    Default Re: Slick wood stairs
    could add a coat with some sand mixed in- ask at paint supply store...
    1,950
    Maryr,
    Timothy Miller is correct. There is a fine silica sand available at paint stores intended exactly for this purpose. It is very fine and not too noticeable even in varnish. In the past, I have used wooden ramps to aid in getting my powerwasher into my work van. I varnished these boards and then gave them one more coat with a little of the traction sand mixed in. I would only put it in the last coat, as any additional plain varnish over it will diminish its traction characteristics.
    Dec 2009
    Casper, Wyoming
    159
    I have heard about a product called skid safe. http://ndclean.com/skidsafe.html. It sound like it could work well for you.
    _______
    Networx.com
    We provide the latest information on how to fix, renovate, and decorate your house using the least amount of resources for the best value.
