    Jul 2008
    7
    Post Low water pressure in shower only
    First of all I would like to thank anyone that can help.
    I am on a public water system and the water pressure is fine throughout our two year old home, except in our master shower.
    This is a relatively recent occurance. There doesn't apprear to be a leak. The only thing I can think of is to snake the pipe or check the opening of the valve to be sure it opens all the way when I turn the (1) handle. Can it be anything else?
    Default Re: Low water pressure in shower only
    Have you checked the shower head first?
    Jul 2008
    7
    Thanks, I removed the head and cleaned it as best I could (the way it was made I couldn't to take it apart) and that solved the problem. Thanks so much, I appreciate it. Dave
