Thread: Frozen pipe
    Jul 2008
    Default Frozen pipe
    I am remodeling my bathroom. I have been trying to unscrew the 2 inch pipe from the bathtub drain that connects to the waste tee. The pipe will not budge. I have used liquid wrench and a 5 ft pipe as leverage to no avail and the pipe is now deformed. Should my next step be to heat the pipe with a torch and try again. I would rather not have to cut the entire line of the vent and waste section. Any suggestions are appreciated.
    Pennsylvania
    246
    Thumbs up Candle wax
    Use cheapo candles.
    Candle wax is an excellent stuff for loosing rusty, seized, over-tighten pipe fitting.
    Heat the pipe warm / hot enough for candle wax to flow inside the pipe threads.
    Loosen pipe/ fittings in normal matter.
    Ask me how I know this!
    Default Re: Candle wax
    Thor .... if BigWalt's suggestion doesn't work try cutting only a small section of pipe. You can replace that section with Fernco coupler and PVC/ABS pipe later when you need to make the connection.
    Just a thought.
    Quote Originally Posted by BigWalt View Post
    Use cheapo candles.
    Ok I'll bite .... how do you know this?
    443
    Default Re: Frozen pipe
    There's a special tool called a dumbell wrench used to remove rust-frozen drains.
    They sometimes also use a pipe-expanding tool (used in automotive work to expand exhaust pipes in muffler systems), carried by Pep Boys, or auto parts stores.
    http://www.hammerzone.com/archives/p...n2/replace.htm
    http://www.terrylove.com/wwwboard/messages/9740.html
    http://www.thisoldhouse.com/toh/tvpr...218679,00.html
