Thread: pulsing sound
    Default pulsing sound
    When I turn on the water in the kitchen, there is a pulsing sound that is made, whether the cold or hot water is turned on. The faucet is a combo hot/cold.
    Sound does not happen on any other fixture in the home.
    Any suggestions?
    Default Re: pulsing sound
    If you have a sprayer attachment for the kitchen faucet it's possibly the cause.
    If you have one of these and you had used the sprayer and shut off the faucet while holding the lever of the sprayer ... the diverter is still engaged. So the next time you turn on the kitchen faucet you will hear pulsing sounds as the flapper inside the diverter moves to allow the water through the spout.
    Possibly the diverter is bypassing , worn or plugged.... in which case just replace the diverter .... they are relatively inexpensive.
    Hope this helps.
    Lakeland ,MN
    356
    Hope this helps.
    Could also be a well pump and the air bladder is damaged. Are you on a well?
    Harry
    Not on a well
    We do have a sprayer and I'll take a look at that.
    Thanks for the help
    Bill
    Let us know how you make out.
