    Jun 2008
    Default Deck sinking in one corner
    I have a covered 10'X 18' deck. It's connected to my house. Everything is solid, except one of the corners (Right - away from house) is sinking about 1/4". It drives me crazy, but I know it's not a safety thing. What can I do to get everything level?
    The deep South
    459
    Default Re: Deck sinking in one corner
    How is the deck supported on that corner ?
    MN
    455
    Personally, if the structure is only 1/4 inch out in 10 or 18 feet I wouldn't worry.
    Jun 2008
    The deck is supported by three 4X6 posts on 12" cement sonotubes. I double checked. It's off more like 1/2" vs. 1/4" like I previously stated. Can I just jack up the post that's a little off and shim it with 1/2" piece of pressure treated wood?
    Thanks for the help guys.
    MN
    455
    The post should be secured or fastened somehow to the concrete pier on the bottom and the deck at the top.
    You would need to unfasten either the top or bottom of the post to place the shim and then refasten the post.
    In my opinion even 1/2 inch out in 18 feet isn't something to loose sleep over.
    Jun 2008
    I agree with you bsum1. I'm not concerned at all from a safety standpoint. It's all about looks. It's kind of like seeing a picture frame on a wall that's slightly off. It's just something that will drive me crazy until I fix it. Do you see any safety concerns with shimming it?
