    Jun 2008
    Default Cast Iron steam heaters around base of floor
    We would like to put a French Door out to a patio from a room that has cast iron steam heaters around the base of the floor. How do we accomplish this. The room in question is on slab. There is not a basement beneath.
Name:	Inside baseboard cast iron heaters.jpg
ID:	1245   Click image for larger version.
Name:	Back of house.jpg
    443
    Default Re: Cast Iron steam heaters around base of floor
    Peggy:
    Are you sure those are steam heat radiators---they look like hot water (hydronic) baseboard convectors.
    Could you provide the model number and brand of the boiler--does the boiler have a glass tube in front to indicate the water level??
    If the heat is steam, is it a two-pipe system for each radiator, or a one-pipe system for each radiator??
    Since you have a slab in that room, it would require cutting into the concrete to some extent, but it could be done.
    You already have a lot of glass in that room, which makes it costly to heat---adding a french door, especially glass, would add some additional costs to your heating bill.
    Why not consult the Yellow Pages under "Heating Contractors" & have one or two installers come over & give you a free estimate of the cost & time factors.
    The site below has several types of convectors (designed for hot water) that are used with french doors---click onto "residential products", then floor vectors, etc.
    http://www.beacon-morris.com
