    Default replacement for claw feet
    Does anyone know where I can get the claw feet for an iron tub?
    6,103
    Default Re: replacement for claw feet
    "As tubs were made by a number of different foundaries the feet come in hundreds of styles and bolt on configurations.
    Because of this tub feet are generally not "switchable" from tub to tub, but there are some that are more common than others. "
    If you know the manufacturer it would be helpful. Here's
    couple of links that might help.
    http://www.vintagetub.com/asp/featur...409&OVNDID=ND1
    and
    http://www.clawfoot-connection.com/tub-feet.htm
    Dec 2009
    Casper, Wyoming
    159
    I saw some listed on ebay. You'll probably get a good deal there. It's worth checking out. Also check http://www.shop4classics.com/product...8&mode=CATALOG. Good luck!
    ______
    Find licensed plumbers in your area.
