    Jun 2008
    Default Can standard ceiling light be adapted for a ceiling fan?
    Can I adapt a normal ceiling light to use with my ceiling fan? light kit choices are pretty limited and I'd like to use a candelabra light (candelabra light kits available are pretty fru-fru). Can I buy the screw socket base anywhere?
    All help and suggestions appreciated.
    6,103
    Default Re: Can standard ceiling light be adapted for a ceiling fan?
    The only limitation is your imagination, your skill, and the weight.
    Jun 2008
    Thanks. Do you know what is involved? I assume I need to get a screw connection.
