Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
  1. #21
    Pennsylvania
    246
    Default Re: A/C unit not working..
    This my be to simple of a question but, did you flip the switch on the thermostat to heat and the turn the temp up past current temp?
    Yes, and I had it on 90 degrees.
    "Life does not go by the book, we learn as we go along".
    You only need two tools in life - WD-40 and Duct Tape.
    If it doesn't move and should, use WD-40.
    If it shouldn't move and does, use the Duct Tape.
  2. #22
    Did the orginal wire setup have only 4 wires hooked up?
  3. #23
    Pennsylvania
    246
    yes, red, blue, green and white.
    I did remove the thermostat, it only has 4 wires.
  4. #24
    5,803
    On the heat pump did you have a "Y" terminal? On some heat pumps you have to have a jumper from "Y" to "W".
  5. #25
    which wires go to which terminal on the thermostat ?
  6. #26
    Pennsylvania
    246
    on thermostat itself.....
    yes, there is Y and W terminal but no jumper...
    let me take pictures of thermstat and post here within 10 minutes.
    FYI.... I did not replace entire length of thermostat wiring.
    Just the junction connection outside to inside of A/C / heater circuit board.
  7. #27
    5,803
    Is there a "Y" on the heat pump?
  8. #28
    Pennsylvania
    246
  9. #29
    Pennsylvania
    246
    I have to go outside during the day.....right now it is raining like MOFO....
    question.......
    Is there outside thermostat that prevent heat pump coming on?
  10. #30
    5,803
    I'm going to take a quess here , Red is 24 vac, G is fan, W is heat, and your Blue is cool. The thermostat mearly closes a switch and connect Red to White for heat, Red to Green for the blower motor, and Red to Blue for cooling. So when the cooling is on you should have 24vac on the Green to turn on the blower and on the Blue to turn on the cooling. When you call for heat you should have 24 vac on the Green and the White. Usually Yellow is used for cooling but in your case it seems that Blue was used..
