Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 50
  1. #11
    Pennsylvania
    246
    Talking Re: A/C unit not working..
    Quote Originally Posted by bp21901 View Post
    any DIY project should have a sawzall present when pictures are taken whether it was used or not.
    sawzall? NAH..sawzall is for women. LOL
    Guys uses BFH.
  2. #12
    6,115
    Default Re: A/C unit not working..
    The brown wire you're talking about is thermostat wire, you can pick it up at just about any hardware or big box store. It runs from the unit to the thermostat. I would stick with the right wire because telephone wire has different colors and can cause some confusion for service people.
  3. #13
    Pennsylvania
    246
    What kind of wire would that be?
    What would I cal it?
    I doubt anybody from Home Depot and Lowes would know if I tried to explain to them.
  4. #14
    6,115
    The last time I bought some I just asked for thermostat wire.
  5. #15
    Quote Originally Posted by BigWalt View Post
    That wire is corroded and broken.
    I did a temp repair and lo & behold it works.
    COOL!
  6. #16
    Yep ... like JLM says .... ask for thermostat cable.
    I kinda goofed in my post ... you probably have 5 conductors .... and the thermostat cable conductors are usually 20 or 18 gage.
  7. #17
    Quote Originally Posted by Ravens53 View Post
    I didn't think they had heat pumps up Nort Ehh
    Or for that matter in Minnesota either LOL
    Geez ... you got that right.
    A heat pump for residential is extremely rare around these parts .... I've only heard of one home that has one.
    This is one of those things I'm learning about on this forum.
  8. #18
    Pennsylvania
    246
    Ok, I gotta bring this back alive....
    I replace the wire today.
    Originally, I have 4 conductor wires, red, blue, white and green.
    The wire I just replace has 5 conductors, red, blue, white, green and yellow.
    I just leave yellow wire disconnect.
    Anyway, A/C works, fan works but no heat.
    Could I have bad thermostat?
    Is there a way to by pass thermostat, to check for heat?
    "Life does not go by the book, we learn as we go along".
    You only need two tools in life - WD-40 and Duct Tape.
    If it doesn't move and should, use WD-40.
    If it shouldn't move and does, use the Duct Tape.
  9. #19
    usually it's not a thermostat problem.
  10. #20
    6,115
    This my be to simple of a question but, did you flip the switch on the thermostat to heat and the turn the temp up past current temp?
