Page 5 of 5 FirstFirst ... 345
Results 41 to 50 of 50
  1. #41
    Pennsylvania
    246
    Default Re: A/C unit not working..
    Ok.....it is not a heat pump.
    It is A/C and gas heat furnace assembly. I'll post pictures later.
    I have the panel off and I'm checking few things.
    The pilot light is working correctly...I got mini shock...... you should all see my newly mohawk hairdo....
    anyway, I remove it and check it, it does emitted healthy sparks.
    One thing I notice.... no odor....
    I did shut off gas supply and remove sediment trap. It is clean and it does have gas odor.
    I'm suspecting clogged nozzles because I've seen multiples spider webs.
    "Life does not go by the book, we learn as we go along".
    You only need two tools in life - WD-40 and Duct Tape.
    If it doesn't move and should, use WD-40.
    If it shouldn't move and does, use the Duct Tape.
  2. #42
    Pennsylvania
    246
    Ok, here are updates...
    #1... Spider webs arenít the problem.
    #2....This furnace looks like it has been replaced because the nozzles and other whachamacallit is either replaces or cleaned.
    #3.... Found the problem...little piece of plastic fell out when I was removing gas line to automatic shut off valve inside the furnace. [see picture]
    #4.... Clean the valve and nozzles...[ I had them out anyway]
    #5.... Replace rusty 1/2" pipe union and reassemble whole thing....
    Viola.....works flawlessly......
  3. #43
    Great stuff
    So .... was this plastic piece supposed to be there or not ?
  4. #44
    Pennsylvania
    246
    Great stuff
    it is not solid plastic, it is more like a plastic wrap covering pipe opening, valve opening prior assembly or shipping ??
    The thickness of this plastic is equivalent to plastic wrap on meat package.
    I just couldn't tell you where it is coming from but I found it inside the pipe near the shut off valve.
  5. #45
    Quote Originally Posted by BigWalt View Post
    Ah ... so it was blocking gas flow to the valve?
  6. #46
    Pennsylvania
    246
    yeah, like I mention earlier....no fuel odor....
  7. #47
    Pennsylvania
    246
    Today, we got no heat....... ... great......
    I double check my previous repairs.....everything is perfect.
    There is some kind of thermostat sensor on top of shield [right above burner assembly.]
    See the picture somewhere above....
    it is white wires with button on top...kinda like circuit breaker to reset......I believe the sensor turn off the gas valve when the shield gets too hot.
    Anyway, I press the button and the burner comes on...
    I thought I could have defective sensor until I look at the burner itself.
    Do the flames suppose to come out from the center of the burner only or edge of the burner and center of the burner...look at the picture below, you'll see blue highlight area. It is the part I'm talking about....
    Notice...it is not the actual burner but it is very similar.
  8. #48
    5,939
    Yes there should be a flame across the "blue" area in your picture, that's how the flame goes from one burner to the next. That area clogs easily due to rust or dirt and is easy to clean.
  9. #49
    Pennsylvania
    246
    Ok, Thanks..... I thought the flames must come out of center hole.
    It must be the sensor itself, unfortunately it is working flawlessly today. I tried to wiggled the sensor wiring and pushing the button, but the heater still work. I'm going to wait until it stops working then check the sensor.
  10. #50
    Yeah, could you re-post your image? It's not working.
