    Default Tiling a bathroom floor
    I am currently removing an old linoleum floor from a bathroom. It is so old that it is spliting in half and the bottom and backing paper are sticking to the floor in some areas while the top design is coming up. I am planning on tiling the floor. Should I worry about removing the remaining backing paper/adhesive and if so how? If not should I use some sort of backer board or self leveling cement or some such product? Any help would be appreciated. Thank You
    5
    Default Re: Tiling a bathroom floor
    You could have avoided taking that tile off and just install backer board and tile over that. It shouldn't be much of a diff. leaving some glue or tile as long it's not exagerated leaving to much of a offset or bump on the floor.
