Thread: reel lawn mower
    Jun 2008
    Default reel lawn mower
    does anyone know how to sharpen the blades of a reel lawn mower?
    Jun 2008
    Default Re: reel lawn mower
    I have used both a hand file and a rotary tool- dremel with stone attachment worked the best for me. Good Luck
    980
    Quote Originally Posted by caaceto View Post
    and dremel makes an attachment that goes on the dremel tool that will keep the angle the same the whole length of the blade.
    Jun 2008
    New Jersey
    Your local hardware store can sharpen it for a small cost.
    Sep 2008
    47
    Smile Re: reel lawn mower
    I own a 20" Scotts Classic and the Manufacture suggests using the sharpening kit which contains an application brush, grinding compound, and back-lapping crank. The crank allows the reel the spin backwards . It uses the straight blade located on the unit to self sharpen. After you have sharpened the reel you can test its ability by shredding notebook paper in various locations along the straight blade. It should shear perfectly at all points. I usually hit it WD-40 before and after use to keep the reels cutting surface as pristine as possible avoiding having to do these steps no more than once every 2 years.
