    Jun 2008
    Default Insulation for bay window
    I have a 115 yr old house that has a bay window. I replaced the windows but there is still a lot of air leakage in the winter. What is the best way to insulate?
    Default Re: Insulation for bay window
    I'm guessing you are having drafts around the window and the wall ?
    If so ..... then carefully remove the molding around the window and use spray foam in a can to fill the gap between the window frame and the wall framing.
    Hopefully this helps.
    Lakeland ,MN
    356
    I would say the same thing Canuk has said.only I would add make sure you use the spray foam that is specifically used for around windows. The foam for windows does not over expand and make the window to tight open and close.
    Harry
    Jun 2008
    I would like to avoid possibly destroying the plaster walls. Could I achieve the same results by doing this from the outside?
    Ravens53 ... good point regarding expanding foam.
    Basically there are 3 types available in a can for consumers:
    1. low expansion
    2. medium expansion
    3. high expansion
    with high expansion types apply what's looks to be not enough because some will expand 10 times it's volume.
    Yep ... remove the molding around the outside and apply the foam.
    However ... doing it from the outside means that you need to make sure to seal the molding around the window with caulk. Otherwise you will have moisture issues ... that's why it's generally done from the inside.
