    Jun 2008
    Reading, PA
    Default drilling thru floor joist
    So for a 2 by 8 floor joist, what is the largest hole you are allowed to drill through it, and do they make flat bracing for larger holes(ie, more of joist removed)?
    Default Re: drilling thru floor joist
    Holes can't be larger than 1/3 the depth of the member and not closer than 2 inches to the top or bottom of the member.
    So for a 2x8 that equates to a hole of 2.5 ( 2.49) inches.
    Here's a thread that discusses this issue: http://advice.thisoldhouse.com/showthread.php?t=5798
    Jun 2008
    Reading, PA
    Thank you, CANUK!!
