Thread: Wood beams
    Jun 2008
    14
    Default Wood beams
    I am considering putting up two solid wood beams in my sun room. There is a 15 foot span and I am wondering if these would "sag" after time? The beams I am considering are either a 6 inch or 8 inch... most likely, the 8 inch will win out.
    Sand Springs, OK
    467
    Default Re: Wood beams
    Are these structural or just aesthetic.
    The properly structured structural beam won't sag for a very long time
    If you're looking to install aesthetic beams I would go with faux beams made of ply wood.
    Debby in Oklahoma
    Jun 2008
    14
    Actually, the room I'm wanting to put them in has a problem with the ceiling cracking. The room is an addition to the main house, and was built as a deck would be built (using 4X4's that are sitting on a concrete pier. I never did have an engineer look at it, but a couple of (self proclaimed) carpenters said they thought the weight of the snow is causing the walls to spread a little, and thus the ceiling cracks. The cracks open up in the winter months and close during the warmer months.
    So, I was hoping I could attach a "shelf" on either side of the wall, lagged to the studs in the wall. Once that was done, I was hoping to put a beam (15 foot span) and lag it to the (already) lagged shelf. Hoping the would help prevent the wall's from "spreading".
    So I guess the answer to your question would be, both structurally and for aesthetics. The beam I'm wanting to put up is not an engineered beam, but a rustic wood beam.
    Jun 2008
    14
    Well, thanks for the replies I did get. I'll keep checking to see if I can find an answer to my question.
