Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 61
  1. #51
    Default Re: Spraying water based Polyurethane
    Or did I miss another meeting?
    Yes, you did, it was the 11th step meeting. Now you have to start over ...
  2. #52
    Aye .... Eh !
  3. #53
    You didn't get the memo ?
  4. #54
    Sorry guys, but YukYuk is correct. For the clearest finish you should use high gloss for the sub coats and the satin or semi-gloss for the last coat. It's just the way it works.
    I dunno if that's absolutely correct.
    The only times I've encountered a milky finish is from one of two things.
    Generally a silica flattening agent is incorporated in the formula that settles at the bottom of the can. If it isn't thoroughly mixed can cause a milky or haze appearance.
    The other issue is from stain that hasn't thoroughly dried before applying the poly.
    If the moisture is trapped under the poly this will cause a hazy - milky finish.
    This is more likely when doing finish to furniture for example .... since Harry didn't stain then he won't have any issue with that part .
    At least that's been my experience .
  5. #55
    im good, drywalls hung... we used cod fishing hooks.
    That's brilliant.
    I'm thinking those cod hooks are a fair size.
    geez ... if they're large enough they'll be secured to framing and you just hang the sheetrock on the hooks. If they poke through enough they can double as picture hooks.
    Haven't figured out the ceiling ones though.
    Out here on the prairies we use bailing twine and barbed wire fencing staples.
    So as you can see the staples thing isn't a new idea.
    as for the thread, 10% mineral spirits to cut down varathane, or woule 15% be better for the first coat to dry quicker, humidity is hell right now
    That's a tough call .... myself would probably go with only the 10%.
  6. #56
    980
    Wait a minute, you can't just let someone in! We gotta vote or something! All in favor of letting Raven into the fold say Aye. (or to you canuks and Yuper peninsula types Ehy! )
    mr spruce sir please don't put those fromt he upper in the same catagory as our northern friends we from that part of the country my talk similar doesn't mean we are alike. and just because my grandfather is a canuk (french canadian)doesn't mean a thing.
  7. #57
    Quote Originally Posted by havanagranite View Post
    So what are you saying, ehy?
  8. #58
    6,077
    Quote Canuk
    If you put a pin with the same shear strenght as a drywall screw through the eyelet and it's long enough it will hold better than a drywall screw.
  9. #59
    6,077
    And you can build a robotic transformer rack with lasers, full hydraulics, computer controlled,and a built in work site radio that will install 256 hooks at one time and automatically put the drywall sheet into place. That way you wouldn't even have to be there so you could spend more time with your family having intelligent discussions.
  10. #60
    6,077
    Quote Originally Posted by YukYuk View Post
    Make that intelligent discourse!
    I guess I just lost my head!
