Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
    Lakeland ,MN
    356
    Default Spraying water based Polyurethane
    I just finished a sunroom with Birch tongue and groove paneling.
    I want to spray a clear water base poly as it does not yellow as much as oil base.
    I am using a HPLV air gun.
    Does this need to be thinned and if it does what shall i cut it with?
    Harry
    6,063
    Default Re: Spraying water based Polyurethane
    You thin it with water if needed. Some polys need to be thined others don't. Wipe on poly is usually thin enough.
    Lakeland ,MN
    356
    Thanks all!!! this weekend I am going to give it a try. I'll have pictures
    Harry
    You might need to check the viscousity of the material to be sprayed. Usually sprayers will have a spec as to the viscousity value.
    Check this link : http://ronjoseph.com/Q&A/B1503_zahn_cup.htm
    When applying poly by brush, it is thinned so that it is absorbed deeper into the wood for a stronger bond and longer lasting finish. While you may not need to thin the material for spraying purposes, I'd be inclined to do it for penetrative purposes. The polys I've used are usually thinned 25-50% for the first coat or two, then applied at full strength.
    Side note: STAY AWAY FROM MINWAX POLYS!!!!!! They do nothing but bubble and foam, and I'd suspect that spray application won't help matters any. Both McKloskies and General Finishes make an excellent poly.
    6,063
    If you are going to use a water based product you should raise the grain before you sand.
    One reason to thin the WB poly is that it is so fast drying. Thinning helps prevent the droplets from forming a skin on their surface so they end up as a surface coat. I'm sure you've all seen furniture that you can run your thumb nail across and scrap off the finish.
    Lakeland ,MN
    356
    I am using water base poly as I have been told it does not yellow as much as a oil base poly.
    There is a viscosity stick with the sprayer.
    I am going to use a pratice piece first.
    I thought I would run it past some people that have personally done this before. As I never believe all that you read they always make it more simple than it really is. I have a lot of time in this project and do not want it ruined by a poor finish.
    It is a 14 X 14 sunroom with a raised ceiling all tounge grove variegated birch various width boards. I'll post pictures when I am done. I hope it does well
    Harry
    Harry ... good luck ... I'm sure you'll do a good job.
    Lakeland ,MN
    356
    Just a update on my first time using a HPLV spray gun. I bought Varathane water based Satin Polyurethane. I tested the poly for the proper viscosity loaded up the gun with the thin aplication needle. I have so far used two gallons in two coats and it looks like I will need 2 more but the resualts are what I had hoped for. Here is the picture of the room before I sprayed. I had to make some corner blocks as I had three pieces of crown molding that came together at one spot.
    I hope to be done by wednesday and in few weeks when I am done I shall have pictures
ID:	1240   Click image for larger version.
ID:	1241   Click image for larger version.
ID:	1242   Click image for larger version.
ID:	1243   Click image for larger version.
    Harry
    What?!?!? .... You're not done yet ?????
    Nice job .... not bad for a sparky.
