    Default No water from hot side...water from cold side
    Yesterday morning I went to turn on the hot water and had nothing. No water at all. I thought that maybe my pipes had frozen overnight, but I had cold water from the cold tap. Then when I turned open the hot water taps in the house and turned one of the cold taps on, I had cold water coming out of the hot water side. Confused!!! I'm wondering if it's not a frozen pipe, but my WH? It is only 7 months old though.
    6,047
    Default Re: No water from hot side...water from cold side
    You probably have a frozen line. Opening the cold with the hot spigots open you are probably feeding cold water through the mixing valve and into the hot pipes.
    Smile Re: No water from hot side...water from cold side
    Thanks for your time and effort, Jack. I appreciate it. I have since determined and pinpointed where I did have a frozen line and caught it just in time to stop any costly damage. I'm back to living life with hot water again! Thanks for your help!
