    Jun 2008
    Default back flow flap valve
    My drains backed up in the basement of my 1941 house, after a big rain. The plumber said my problem was due to a back flow flap valve that was bad. He wants to break up my floor and replace the iron pipe with PVC. Does this sound correct?
    Default Re: back flow flap valve
    ondraa .... unless a back flow valve had been installed to your drain in the recent past it's unlikely there is one based on the vintage of your home.
    If one does exist and is faulty and depending on type and location .... it might be a simple replacement or repair.
    The simple ball type ( check valve) usually can be found in the floor drain and for the most part is relatively easy to replace.
    If it is the flap type back flow valve located on the main drain line of the home .... there is usually an inspection cover than can be removed .... there might just be some debris obstructing the flap to close. If this type is faulty then the floor will have to be broken open in order to detach it from the drain line and reinstall a new one.
    Other than that I'm not sure why the plumber is recommending replacing the cast iron pipe with PVC .... unless they had run a scope through the pipe and found a break.
    There was a previous discussion on back flow valves that you may find useful in this link:
    http://advice.thisoldhouse.com/showt...ack+flow+valve
    Hope this helps.
    Nashville, TN
    149
    Your drain should have nothing to do with the rainfall and the groundwater. Your floor drain should be part of your sewer system which allows the sewer water to go to the treatment plant. Now if the drain pipes are cast iron or galvanized piping they might be rusted through and then allowing the groundwater (from the rainfall) to soak up into the drain line and then enter your home.
    Process of elimination. Good luck.
    If the foundation perimeter drains empty into the house main line .... will be affected by heavy rainfall.
    Memphis, not Egypt
    183
    Your house is old and messed up. Who Knows? Spend a whole bunch of money or move.
