Results 1 to 7 of 7
    Sep 2007
    11
    Default How to clean fixed screens on porch?
    What is the best way to clean metal fixed screens on porch?
    They have pollen and dust etc on them and I dont want to stretch
    them by wiping them down.
    Lakeland ,MN
    356
    Default Re: How to clean fixed screens on porch?
    Quote Originally Posted by sarah View Post
    You could vacuum them.
    I always used soapy water and a soft brush then hosed them off. I would suggest dot to push hard when using the soap and brush. I never had a problem
    Harry
    2,000
    I've always used a soft brush, soap and a hose to clean mine. Never damaged one yet.
    980
    when cleaning screens we use a pump up sprayer that has a bleach solution in it to kill any molds on them then use a soft brush on a handle and window cleaning solution (both available at home depot in their outdoor area usually near the mowers and grills) to wash them down, rinse and reinstall.
    6,015
    Power washer form the inside, no bush, little labor, and done.
    980
    a "squeegee" for the screens are you kidding? nice way to stretch the screens
    980
    Quote Originally Posted by YukYuk View Post
    I avoid chlorine bleach on nylon or fabric screening, tends to make them brittle and deterioriate faster.
    A stiff wide paint brush works well as a screen cleaning tool. to wipe on, mild scrub motion and wipe off. A window washer's squeegie (spelling?) to break tension of the clinging dirty washing solution to remove, and rinse water using squeegie with pulling strokes down towards the ground, works well too, and doesn't stress the screening against the spline.
    if you were using straight bleach and then just leaving it set then yes I would agree with you but not in this setting
